Where is the ECU for rs3000 98 Camry?
[blockquote]
OK. I have located the glass break sensor that is behind the drivers side kick panel. I see wires running from the sensorup/higher in behind the dash.
I still can not see the ECU. It has to be further up and somewhere behind the dash... [/blockquote]
How do you get to the ECU to push the button to start the programming process???
Does anyone have a link that shows how to get in behind the dash where the security panel and fog light switch are located?
Thanks
Thanks
Open the panel on the left side of the steering wheel. The panel is; a mirror control, light dimmer, empty, and then the LED security with a microphone. After opening, look up. There should be a black device there. Cut the BLACK zip-tie (this will cause the ECU to fall out of place). There you will be able to obtain the ECU unit
Richmond71
12-30-2010 06:09 PM
