2003 camry v4(2azfe) to v6(1mzfe)
I am most likely gonna need to replace my engine and was noticing that a v6 1mzfe is a good bit cheaper and would also make me happier...I think the computer/wiring harness would need changed??? What else would be problems or possible areas that need changed/updated?
2003 camry v42azfe to v61mzfe
hes a liar hahaha..
that would be nice idea to put that engine in the camry and make it rwd car... |
Oh crap so the 4 cylinder is front wheel drive and the 6 goes to rear wheel drive?
The 1mzfe was offered as an option for Camry, not sure when it was replaced be the newer model V6.
You will also need a different trans beside computer and wiring. The parts should drop into the car but suggest you find another 4 cylinder rather then try this engine/trans swap. A lot of work, money and it will lower the resale value of the car. |
