92 Camry Oil leak question
I need to know the best way to find an Engine oil leak in my 92 Camry LE? I've put new Valve cover gaskets on, and a new pcv valve but am still having trouble locating the leak. Thinks its coming from the backside of the engine because the oil is leaking onto the exhaust pipe.
Try looking at either end of your engine. Mine leaks at the front and rear main seals (just slightly) Also try poking around your oil pan, that is a pretty common area as well.
When you replaced your valve cover gasket- hopefully you replace the rear cam plug (distributorless) or the distributor O ring (with distributor)- both of which are common leak points for the 4 cylinder.
JJ |
Check the oil pump
The biggest leak turned out to be in the oil pump on my 91. Rubber seal had gotten hard and cracked. Leaked heavily when running.
I am planig to change cam,I dont know how to seal the oil pan.
I sure hope I dont have to pull the pan. |
Originally Posted by Prubback73
(Post 33261)
Originally Posted by JoshInWV
(Post 33265)
You would seal it up by replacing the gasket and rebolting the oil pan up. Not that hard actually. About 10 minutes worth of work. Your cam shaft will take more time than the oil pan :)
JJ |
As Joel_CA said, far more then 10 minutes work, as both surfaces must be spotless.
But may I suggest, rather then replacing seals here, gaskets there and so on. Fully degrease the entire engine + driveline assembly that has oil evident, then, keep an eye on where oil comes from. Will save you a f*** load of time and effort, not to mention money! |
Theres a seal where the distributor shaft spins within the distributor body. When that leaks, it lets engine oil into the distributor body, where it eventually leaks out right where you said.But that would be engine oil, so Im not sure about the "milky" oil?? Is the oil in the engine milky? If so, change oil a couple times to get rid of all the residual moisture.The official story about that distributor shaft seal, is that you have to buy a new distributor. A couple people have figured out how to replace just the seal, but I dont know the details. Search around here... General Tech or maybe DIY.
Originally Posted by Inhimiggenure
(Post 33422)
Cannot say I have ever heard of an internal oil seal in a distributor. There is only the oil seal on the distributor shaft that sits inside the cylinder head, when that leaks you take the distributor out, remove the oil o ring, fit a new one and whack the dizzy back in. |
