92 Camry Oil leak question
I need to know the best way to find an Engine oil leak in my 92 Camry LE? I've put new Valve cover gaskets on, and a new pcv valve but am still having trouble locating the leak. Thinks its coming from the backside of the engine because the oil is leaking onto the exhaust pipe.
JJ
As Joel_CA said, far more then 10 minutes work, as both surfaces must be spotless.
But may I suggest, rather then replacing seals here, gaskets there and so on.
Fully degrease the entire engine + driveline assembly that has oil evident, then, keep an eye on where oil comes from.
Will save you a f*** load of time and effort, not to mention money!
Theres a seal where the distributor shaft spins within the distributor body. When that leaks, it lets engine oil into the distributor body, where it eventually leaks out right where you said.But that would be engine oil, so Im not sure about the "milky" oil?? Is the oil in the engine milky? If so, change oil a couple times to get rid of all the residual moisture.The official story about that distributor shaft seal, is that you have to buy a new distributor. A couple people have figured out how to replace just the seal, but I dont know the details. Search around here... General Tech or maybe DIY.
Cannot say I have ever heard of an internal oil seal in a distributor. There is only the oil seal on the distributor shaft that sits inside the cylinder head, when that leaks you take the distributor out, remove the oil o ring, fit a new one and whack the dizzy back in.
umdaman
May 21, 2013 09:18 PM
lesaroka
Sep 12, 2005 10:58 PM
