97 motor
hello i got a 97 camry 4cyl and it poped. will a 96 fit
oh, I think it will... but if I were you I won't replace it.
well there is a 4 inch hole in the side of the block y not replace it.
The engine would fit but:
Check the ign system. Sometime after 1995 the engine started using a cam sensor then both cam and crank sensors. Make sure the new engine has the same sensor setup as the old. The California emissions standard engine has a different head and other changes. |
