A/C causing Overheating
Ok guys! got one for ya.
i am not a beginner when i comes to engines, however i am stumped. 1988 Camry 3SFE Car only overheats when a/c is turned on. I replaced t-stat (w/ 180f) Replaced Radiator fan Switch Drained/Flushed/Fill Radiator with professional cleaner and water (radiator resivoir needs weekly refilling) will a/c compressor overheat and raise temp? The radiator fans do work. (if they run properly is a question) Could it be indicator gauge sensor? Could it be a faulty Water Pump? Radiator Cap is new and at 13lbs All fuses are good and/or replaced Without a/c car temp runs fine. (and in winter) Im familiar with engine coolant systems and fixing them, just not diagnosing them. thanks for your help |
