A/C causing Overheating
Old Jul 30, 2009 | 05:52 PM
wcfyrfytr's Avatar
Default A/C causing Overheating
Ok guys! got one for ya.
i am not a beginner when i comes to engines, however i am stumped.
1988 Camry 3SFE
Car only overheats when a/c is turned on.
I replaced t-stat (w/ 180f)
Replaced Radiator fan Switch
Drained/Flushed/Fill Radiator with professional cleaner and water
(radiator resivoir needs weekly refilling)
will a/c compressor overheat and raise temp?
The radiator fans do work. (if they run properly is a question)
Could it be indicator gauge sensor?
Could it be a faulty Water Pump?
Radiator Cap is new and at 13lbs
All fuses are good and/or replaced
Without a/c car temp runs fine. (and in winter)
Im familiar with engine coolant systems and fixing them, just not diagnosing them.
thanks for your help
Karl99
Nov 15, 2009 10:18 PM
wcfyrfytr
Aug 7, 2009 08:54 PM
hondaelement
Apr 5, 2009 08:48 PM
spup345
Aug 6, 2007 03:54 PM
camryn00b
Jan 21, 2007 12:07 AM
