Coolant leak in 1995 Camry
Hi I was driving yesterday and started to hear what I can describe as a scraping noise it sounded like something was loose and wobbling near the belt/ water pump area. When I would get over 30 I wouldn't hear it as much but idling and accelerating I would hear it on and off. I tried to make it home ASAP but I noticed steam coming out and the temp gauge start to rise so I stopped. I let the car cool down and checked the coolant level. It was low so I put more in. I went in the store and came back out and all the coolant I just put in was on the ground. I then put a little water in to see if I could find the leak. There is a tiny hole near the top radiator hose where the timing belt cover is. The timing belt cover also looks like it's not flush(I am not very knowledgeable about cars so I may be wrong) the car will start for a second and shut off now. Any coolant I put in leaks right out as soon as I put it in. What could the problem be? I can't get it to a shop right now
What engine type, V6 or 4-cylinder?
Is the coolant coming out from the passenger fender side of the of the engine? Is coolant coming out of the hole you mentioned? Is this a hole in the radiator hose or in the metal fitting on the engine the hose slides onto? Did the temp gauge get into the red and if so for how long? Did you drive the car home from the store? If not did the engine ever start up after trying to fill with coolant? When investigating just add water, perhaps distilled if you have it, as no need to run coolant onto the ground. Don't run or attempt to start engine until finding the leak. If a scrapping noise was heard it has happened the water pump bearing fails which can be dramatic. Suggest remove the front passenger tire then have someone add water while you watch at the bottom of the timing cover for leakage. |
(Post 83587)
Is the source of the leak the hole? You can see the hole, fill with water and watch for leak.
I think there is another leak besides the hole. I have to get some better light to look. I haven't had a chance to look during the day
Yes,wait until day.
Remove the tire then fill and look for water coming out from under the timing belt cover. There is a small plastic shield in the inner wheel well that can be removed to be better see the cover. Make sure the car is secure on blocks or jack stand before putting your head into the wheel well. If water coming out from under the cover the water pump may be leaking. Again the pump can fail, make noise. The cover would need to be removed to access. If you don't know auto repairs this may be a job for a mechanic but DIY's have replaced pumps. Post back with your findings tomorrow. |
Thank you very much. I will look in the morning and report back. Have a good night!
I checked it again this morning and took a few pics to help. I however don't know how to post pics. The leak is coming from the bottom front part of the timing belt cover. Also the cover doesn't look to be flush with the engine.
1 Attachment(s)
The leak is coming from below the bolt on that arm in the middle
1 Attachment(s)
Cover bends a little bit
