engine wont start
I dont know i have couple of peoples on xfire told me its my Fuel filter but i dont know if its the fuel filter or the spark plug, My engine lacks alot of power it just wont start unless you jupstart the car.
RE: engine wont start
i have a 1997 toyota camry XLE 4 door. IT suck so bad that my car is sitting outside not going nowere if you can help me get it start and running i will give you 50-100$
where are you from and what is it doing?
im from florida st. petersburg, I just put new sparkplug and seem like it not starting i charged the battery and it looks like it lacks alot of power. I turn on the headlight and it makes some weird noise for 20 seconds than stop out of power. Can you please help me if i can get it start and running i would like to give the person 50-100$
The problem sounds like its either in the starting, charging, or fuel system.
Does the starter operate? If not, theres your problem. Plugs and wires can affect this. However, if you have replaced them you have eliminated that section of possibility unless of course you got a bad set. Did you gap the plugs to the appropriate clearance when you installed them? (If applicable.) See to it that you got the appropriate plugs for your car. The battery that you installed is new correct? You may want to take a multimeter and set it on the "20" volt scale. Place the positive and negative leads across the appropriate battery terminals and the meter SHOULD read 12-12.6 volts. I would like to hear more about this noise that you are hearing when you turn the headlights on. Do the headlights dim any at all? Best of luck, Black00GTS |
it make some weird noise like static shocking or something it really losing power badly..
i changed the new starter it works good but it just wont start the engine when you turn the key it sounds like it is stuck and when iturn on the light switch it sounds wierd..
Sounds like the altanator.
battery....
