engine wont start
Old Oct 30, 2006 | 08:08 PM
ThaiCamry97's Avatar
Default engine wont start
I dont know i have couple of peoples on xfire told me its my Fuel filter but i dont know if its the fuel filter or the spark plug, My engine lacks alot of power it just wont start unless you jupstart the car.
Old Oct 30, 2006 | 08:16 PM
Default RE: engine wont start
i have a 1997 toyota camry XLE 4 door. IT suck so bad that my car is sitting outside not going nowere if you can help me get it start and running i will give you 50-100$
Old Nov 1, 2006 | 04:57 PM
lavalleemike's Avatar
where are you from and what is it doing?
Old Nov 11, 2006 | 06:53 PM
im from florida st. petersburg, I just put new sparkplug and seem like it not starting i charged the battery and it looks like it lacks alot of power. I turn on the headlight and it makes some weird noise for 20 seconds than stop out of power. Can you please help me if i can get it start and running i would like to give the person 50-100$
Old Nov 12, 2006 | 10:57 PM
Black00GTS's Avatar
The problem sounds like its either in the starting, charging, or fuel system.
Does the starter operate? If not, theres your problem.
Plugs and wires can affect this. However, if you have replaced them you have eliminated that section of possibility unless of course you got a bad set. Did you gap the plugs to the appropriate clearance when you installed them? (If applicable.) See to it that you got the appropriate plugs for your car. The battery that you installed is new correct? You may want to take a multimeter and set it on the "20" volt scale. Place the positive and negative leads across the appropriate battery terminals and the meter SHOULD read 12-12.6 volts.
I would like to hear more about this noise that you are hearing when you turn the headlights on. Do the headlights dim any at all?
Best of luck,
Black00GTS
Old Nov 16, 2006 | 11:58 PM
it make some weird noise like static shocking or something it really losing power badly..
Old Nov 16, 2006 | 11:59 PM
i changed the new starter it works good but it just wont start the engine when you turn the key it sounds like it is stuck and when iturn on the light switch it sounds wierd..
Old Dec 4, 2006 | 10:42 AM
99camrytrd's Avatar
Sounds like the altanator.
Old Dec 29, 2006 | 12:12 AM
bpodskalny's Avatar
battery....
freedonutss
Oct 16, 2008 01:02 PM
mrmojorisinphan
Feb 6, 2008 07:50 PM
blazinxpk
Jan 9, 2008 10:18 PM
deanp
Jul 11, 2007 08:48 PM
rtullar
Oct 18, 2006 04:25 PM
