Help with 99 camry trans problem!!!
Car Specs:
- 1999 Toyota Camry LE - four cylinder engine - A140E Automatic Transmission Problem: The car will not pull in D, 4, L or overdrive. It just revs as if the selector is placed in neutral. it will go slowly if force the gas. The car DOES work in reverse. The car had a leak before, and had to pull over the side of the street and was not moving when fluid was out. I added some PEAK ATF D3 to it and ran the selector through all the postions and worked for the last 3 months. Then just recently the car started jerking when taking off at low speed, so i did a flush to the transmission. Replace gasket, drain and add Toyota ATF. i added 2.6 Quart of ATF as recommended by dealer. Now the car only works in Reverse, when in drive it seems like its low on fluid. So i added another half quart of ATF to see if it helps. same problem.. Cant figure out what the problem might be...... Do any of you have a suggestion of something to try? Or is it as bad as I have feared? If the transmission needs to be replaced or rebuilt? Thanks in advance |
Dont Flush
When you had the first symptom (low fluid) then added. Your tranny OVERHEATED causing the damage to FORWARD Clutches amoung other things.
When the tranny is flushed ( Verses drain, check magnets and fill ) you can dislodge debris that can damage other things like the solonoids. Rebuild or replaced the tranny.:o |
