Help help help
ok
so i just burnt a valve in my 3s-fe. so now i have an excuse for a swap. could i bolt in a 3sgte? if so, what axles, shift linkages and all that could i use? |
I think the engine uses the same block as the 3S.
well i know the 5sfe and the 3sfe can be swapped pretty easily due to them having the same engine mounts. and i know that the 5sfe and 3sgte also uses the same mounts. so im 90% sure that the 3sgte will bolt up just fine. as for shift linkages and axels do you know off the top of your head what tranny you have?
no. i have no idea..
its a 1989 3S-FE camry. if that helps.. i can order a 3S-GTE form jdmsource.com for 1500. i just dont know what is interchangeable between cars, such as the axles, shift linkages, harnesses, etc. |
and also..
is the 3sgte for the celica any different from the mr2 3sgte? besides the celica being one of those top mounted intercoolers i think? |
