Idle issue on a 2002
Hey All I am new here. I am having a issue with the idle.
The engine was recently replaced by me and a buddy of mine. The car is running fine or appears to be running fine, but I have a check engine light. I had that checked upon and the shop said I had misfiring in all cylinders. So they suggested new spark plugs and since I have not replaced them, I figured I would get new irridium ones. I gapped them to .044 and installed them. Now it is having a difficult time holding idle and when its barely holding idle, it tends to be very low. Is there a way to adjust idle on the 2002 Camry? I am a Honda guy so this is new to me. I plan on taking the car on a long trip to AZ tomorrow and back over the weekend, so I would like to resolve the idling issue. Thank you, Shah |
This link might help:
http://highlanderclub.ru/files/manua...c0e/onvein.pdf If you car is a 4 cylinder its the same engine. If a V6, make sure the plugs are dual electrode, check the ign coils. The idle is fixed by the computer. |
I think the idle fixed itself, it just took 20 miles of driving :)
Ah, whenever the battery is disconnected the idle can have issues until the computer sorts itself out. As you may have discovered.
