Idle issues Help pleaseee
I have a 93 camry 4cly with 152500miles on it. When I start the engine and its a normal idle (when warm) it would drop excessively but won't stall it will just pick slowly and go back to normal idle then sometimes wen i hault to a stop it does the same..
if someone could help |
RE: Idle issues Help pleaseee
Sounds like the idle air control (IAC) valve needs cleaning. This valve uses bypass air around the throttle plate to adjust engine idle.
To access remove the large plastic air intake pipe connected to the throttle body. Look inside the throttle body at the body to see a rectangle slot, this is the air intake for the valve. Obtain a can of spray throttle body cleaner from the auto parts store. The one that comes with a small attachable spray hose. Make sure the cleaner is safe to use with O2 sensors, catalytic converters and plastics (the valve is plastic). Find the throttle pulley on the side of the throttle body. Start the engine and using the pulley operate the engine at a high RPM while you spray cleaner into the slot. Use a little at a time or you will stall the engine. |
[Deleted]
[Deleted by Admins]
Does it really matter what toyota calls it? The function and maintenance are whats important. And if you look on ebay, you'll still find it as IAC:
http://cgi.ebay.com/ebaymotors/TOYOT...spagenameZWDVW And unless you're theo ne who designed it and named it, what does it matter to you anyways? Why do you feel the need to insult people you dont know? And I checked that thread you left, I saw your jap honda and the civics, but wheres ur camry? |
[Deleted]
[Deleted by Admins]
[Deleted]
[Deleted by Admins]
Heyy thanks! soo much mann. The idling is fixed..thanks so much my dudes!
[Deleted]
[Deleted by Admins]
Then why the **** are you here? you dont even own a camry and you wanna ban other people? Dont ****in talk **** like you're the ****in man in this world because you have a couple ricer pieces of ****. You prolly googled the cars anyways. Who the **** do you htink you are tellin us our cars are ****? Everyone has an opinion and I dont think anyone here wants to hear yours. Unlike you, who only knows hoe to talk **** about people, me and toyomoho actually help people to fix the **** that needs fixing. if you aint here to help out camry enthusiasts get the **** off. you aint wanted here.
