Idle issues Help pleaseee
Old Apr 16, 2008 | 12:35 AM
cisco2992's Avatar
Default Idle issues Help pleaseee
I have a 93 camry 4cly with 152500miles on it. When I start the engine and its a normal idle (when warm) it would drop excessively but won't stall it will just pick slowly and go back to normal idle then sometimes wen i hault to a stop it does the same..
if someone could help
Old Apr 16, 2008 | 01:01 PM
Default RE: Idle issues Help pleaseee
Sounds like the idle air control (IAC) valve needs cleaning. This valve uses bypass air around the throttle plate to adjust engine idle.
To access remove the large plastic air intake pipe connected to the throttle body. Look inside the throttle body at the body to see a rectangle slot, this is the air intake for the valve.
Obtain a can of spray throttle body cleaner from the auto parts store. The one that comes with a small attachable spray hose. Make sure the cleaner is safe to use with O2 sensors, catalytic converters and plastics (the valve is plastic).
Find the throttle pulley on the side of the throttle body. Start the engine and using the pulley operate the engine at a high RPM while you spray cleaner into the slot. Use a little at a time or you will stall the engine.
Old Apr 16, 2008 | 02:22 PM
Deleted User's Avatar
Banned
Default [Deleted]
[Deleted by Admins]
Old Apr 16, 2008 | 09:31 PM
94camguy's Avatar
Does it really matter what toyota calls it? The function and maintenance are whats important. And if you look on ebay, you'll still find it as IAC:
http://cgi.ebay.com/ebaymotors/TOYOT...spagenameZWDVW
And unless you're theo ne who designed it and named it, what does it matter to you anyways? Why do you feel the need to insult people you dont know? And I checked that thread you left, I saw your jap honda and the civics, but wheres ur camry?
Old Apr 17, 2008 | 10:41 AM
Banned
Default [Deleted]
[Deleted by Admins]
Old Apr 17, 2008 | 10:43 AM
Banned
Default [Deleted]
[Deleted by Admins]
Old Apr 17, 2008 | 09:48 PM
cisco2992's Avatar
Heyy thanks! soo much mann. The idling is fixed..thanks so much my dudes!
Old Apr 18, 2008 | 01:08 AM
Banned
Default [Deleted]
[Deleted by Admins]
Old Apr 19, 2008 | 09:38 AM
94camguy's Avatar
Then why the **** are you here? you dont even own a camry and you wanna ban other people? Dont ****in talk **** like you're the ****in man in this world because you have a couple ricer pieces of ****. You prolly googled the cars anyways. Who the **** do you htink you are tellin us our cars are ****? Everyone has an opinion and I dont think anyone here wants to hear yours. Unlike you, who only knows hoe to talk **** about people, me and toyomoho actually help people to fix the **** that needs fixing. if you aint here to help out camry enthusiasts get the **** off. you aint wanted here.
Aug 14, 2015 06:31 PM
dantheman
Apr 15, 2015 04:18 PM
thirdlaw
Nov 23, 2010 09:59 AM
tja349
May 23, 2008 10:55 AM
cisco2992
Apr 16, 2008 12:35 AM
