reversing noize / noize after acceleration let off
i have 2 questions
q1: when i am in reverse and start to go backwards no matter how fast/slow my car makes a really loud zzzzzzz noize i know cars do make a slight zzzz noize in reverse my mine is quite loud what could this be caused from? q2 when i sit on the spot and give my car a rev as i let off the acceleration i notice a slight shh noize as the car comes back down from the revs what could this also be thanks heaps and i hope to get a reply soon cheers Guy... |
RE: reversing noize / noize after acceleration let off
need more info..
year and modle? auto or manual? 4 or 6 cylinder? the more info you give us the better |
it is a
1991 toyota camry sv21 4cylender manual gearbox 3sfe engine cheers.. |
Reverse/Accelration Noises
Many cars have a similar problem.
I have always found bad/weak grounds in the aftermarket stereo deck installs. A weak ground and shotty wiring will cause you speakers to make this noise, many times with the stereo off. A good way to check is disconnect the stereo or speakers from you car and see if the problems gone. Be sure to post again if this is your problem. I am curious and I'm sure others are as well. |
Might be clutch release bearing also called clutch throwout bearing, when pushing clutch while stoped with engine running does noise change?:confused:
