reversing noize / noize after acceleration let off
Old Aug 23, 2007 | 04:00 AM
bassposse's Avatar
Default reversing noize / noize after acceleration let off
i have 2 questions
q1: when i am in reverse and start to go backwards no matter how fast/slow my car makes a really loud zzzzzzz noize i know cars do make a slight zzzz noize in reverse my mine is quite loud what could this be caused from?
q2 when i sit on the spot and give my car a rev as i let off the acceleration i notice a slight shh noize as the car comes back down from the revs what could this also be
thanks heaps and i hope to get a reply soon
cheers Guy...
Old Aug 26, 2007 | 03:32 PM
toyoboy's Avatar
Default RE: reversing noize / noize after acceleration let off
need more info..
year and modle?
auto or manual?
4 or 6 cylinder?
the more info you give us the better
Old Aug 27, 2007 | 05:19 AM
bassposse's Avatar
it is a
1991
toyota camry sv21
4cylender
manual gearbox
3sfe engine
cheers..
Old Jul 22, 2009 | 06:26 PM
r4healy's Avatar
Default Reverse/Accelration Noises
Many cars have a similar problem.
I have always found bad/weak grounds in the aftermarket stereo deck installs.
A weak ground and shotty wiring will cause you speakers to make this noise, many times with the stereo off. A good way to check is disconnect the stereo or speakers from you car and see if the problems gone.
Be sure to post again if this is your problem.
I am curious and I'm sure others are as well.
Old Jul 30, 2009 | 09:52 PM
justastreekin's Avatar
Might be clutch release bearing also called clutch throwout bearing, when pushing clutch while stoped with engine running does noise change?
Kayla
Apr 16, 2012 10:40 PM
barney33
Apr 23, 2009 11:30 PM
bobo45
Jul 17, 2008 10:42 PM
Blue07CamNY
Nov 4, 2007 06:13 PM
