Rough idle
So after drive my car around for a while and it comes up to temperature and I turn it off when I try to start it back up it will not idle and even kills it self
Year of car and engine type?
Check ETC sensor and IAC valve (if the engine has one). |
1998 v6 3.0 .
Read up on cleaning the IAC valve. IAC controls idle speed.
Also check for vacuum hose leaks. A bad ETC can also cause issues. Or a crank/cam sensor. |
