Transmission only starts in 2nd Gear
My 1995 Camry 2.2, when I first begin to move the transmission starts in 2nd gear., after the initial start the transmission shifts perfectly. Is the valve body stuck? What can I do to fix this?
The transmission has no 1st gear?
Have you tried forcing the trans into 1st gear manually? |
how do i do that?
Put the gear shifter into low gear.
04 camry
My toyota camry is doing the same thing, I have replaced all solenoids with filter and new fluid. It starts off in second gear when accelerating from a stop and slams into gear when switching from park to drive or drive to reverse. I have tried manually shifting with no change and It did it once before. I took the pan off before installing new solenoids i sent low voltage to solenoid b and it worked temporarily thinking that was the issue but it appeared later and this time nothing is working. I read there is a tcm issue with these can anyone point me in the right direction please
https://cimg4.ibsrv.net/gimg/www.cam...257f346d72.jpg |
Have you researched each trouble code?
