Transmission only starts in 2nd Gear
My 1995 Camry 2.2, when I first begin to move the transmission starts in 2nd gear., after the initial start the transmission shifts perfectly. Is the valve body stuck? What can I do to fix this?
04 camry
My toyota camry is doing the same thing, I have replaced all solenoids with filter and new fluid. It starts off in second gear when accelerating from a stop and slams into gear when switching from park to drive or drive to reverse. I have tried manually shifting with no change and It did it once before. I took the pan off before installing new solenoids i sent low voltage to solenoid b and it worked temporarily thinking that was the issue but it appeared later and this time nothing is working. I read there is a tcm issue with these can anyone point me in the right direction please
h.cardle4
10-21-2013 10:56 PM
h.cardle4
10-19-2013 08:51 PM
