05 2.4 Camry no spark no start
Replaced head. Car ran fine (aside from losing coolant haha) before. I am seeing rpm on scan tool when attempting to start.
Not getting spark. Do I have this wrong? Going to try to upload pictures of my timing. |
1 Attachment(s)
Here are the cams. Crank at tdc as long as cylinder #1 is the one closest to timing chain and furthest from transmission.
I had intake cam notch incorrect. There were 2 notches. Car bow starts then immediately stalls. Misfire codes in all 4 cylinders.
What codes?
Recheck sensor connections, vacuum hoses, etc. Did you install the timing chain per manual instructions including tensioner? |
P0300, p0301, p0302, p0303, p0304
The first time I didn't install correctly haha. Now after 3 manual turns with tensioner on I remain timed. Now just need to figure out what else I've done incorrectly. |
Does the engine still have not spark?
See private message. |
I now have spark. Engine will start then immediately stall. I believe I am missing a vacuum connection at the bottom of the intake. Looks like a square check valve or reservoir. Going to find a diagram and check my lines.
Post photo.
