07 SE slight pull to the right
I just picked up an 07 SE the other day and I noticed sometimes at low speed the car pulls to the right. At first I thought it was out of alignment or something, but it's perfectly fine and higher speeds. I thought I read something about the torque steering could casue this?
RE: 07 SE slight pull to the right
Roads are usually cantered away from the middle to drain water. You need a flat road or surface to determine if it's the road or the car. Higher speeds might be a faster hwy with more than one lane and a flatter surface. You could try the middle of the road if it's safe to do so or an empty parking lot orif you bought the car from a dealer get him to check it out. Warranty?
It could also be that this is the first front wheel drive car I have had in 12 years and I'm not used to it.
