07 SE slight pull to the right
Old Apr 8, 2008 | 03:49 PM
dwilkins69's Avatar
Default 07 SE slight pull to the right
I just picked up an 07 SE the other day and I noticed sometimes at low speed the car pulls to the right. At first I thought it was out of alignment or something, but it's perfectly fine and higher speeds. I thought I read something about the torque steering could casue this?
Old Apr 8, 2008 | 06:40 PM
pedro's Avatar
Default RE: 07 SE slight pull to the right
Roads are usually cantered away from the middle to drain water. You need a flat road or surface to determine if it's the road or the car. Higher speeds might be a faster hwy with more than one lane and a flatter surface. You could try the middle of the road if it's safe to do so or an empty parking lot orif you bought the car from a dealer get him to check it out. Warranty?
Old Apr 9, 2008 | 07:20 AM
dwilkins69's Avatar
It could also be that this is the first front wheel drive car I have had in 12 years and I'm not used to it.
Amekaji87
Dec 4, 2011 02:39 PM
tsidrift1
Jan 16, 2011 03:19 PM
modelbehave
Sep 23, 2009 10:15 PM
beige97camry
Aug 26, 2007 03:36 PM
beige97camry
Aug 21, 2007 09:59 PM
