1995 Toyota Camry will not start
Watup World! Got an issue with my Camry. Earlier I turned it on and it started up fine. I put it in reverse..no problems. I backed up..no problems. I put it in drive..."O/D off" light blinking. Accelerated...car acted like it was going up a hill. Managed to get car halfway up the driveway and I stopped to see if I could fix it. Turned car off..won't crank back up. Won't even try. When I turn the ignition switch, the clock display fades out. I just changed the battery last month. Any suggestions?
If not cranking and lights fade check the cable connections at the battery terminals.
Loose connections, corrosion, damaged battery cable terminal connection with the battery cable itself. If OK, check the battery cable ground wire connection with the chassis. |
Thanks but..
What about the blinking O/D off light?
95 camry
did you ever find out what was wrong with your car, because my camry is doing the same thing and i cant figure out whats wrong with it.
did you ever figure out what was wrong with the car because my camry is currently doing the same thing
