View Poll Results: How much do you love your camry?
This much
0%
That much
0%
Not much
0%
Very Much
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
1995 Toyota Camry will not start
Old Dec 7, 2010 | 05:56 PM
RikoSuav's Avatar
Exclamation 1995 Toyota Camry will not start
Watup World! Got an issue with my Camry. Earlier I turned it on and it started up fine. I put it in reverse..no problems. I backed up..no problems. I put it in drive..."O/D off" light blinking. Accelerated...car acted like it was going up a hill. Managed to get car halfway up the driveway and I stopped to see if I could fix it. Turned car off..won't crank back up. Won't even try. When I turn the ignition switch, the clock display fades out. I just changed the battery last month. Any suggestions?
Old Dec 7, 2010 | 06:32 PM
If not cranking and lights fade check the cable connections at the battery terminals.
Loose connections, corrosion, damaged battery cable terminal connection with the battery cable itself.
If OK, check the battery cable ground wire connection with the chassis.
Old Dec 8, 2010 | 12:27 AM
RikoSuav's Avatar
Default Thanks but..
What about the blinking O/D off light?
Old Apr 15, 2012 | 12:29 PM
mando96's Avatar
Default 95 camry
did you ever find out what was wrong with your car, because my camry is doing the same thing and i cant figure out whats wrong with it.
Old Apr 15, 2012 | 12:31 PM
mando96's Avatar
did you ever figure out what was wrong with the car because my camry is currently doing the same thing
MuganEjaz
Jul 17, 2013 06:05 PM
jfirusta
Oct 9, 2011 08:09 PM
khanna01
Feb 24, 2011 03:22 AM
wdwilliams
Jul 17, 2010 02:59 AM
brandon_bauer
Jun 18, 2010 12:46 PM
