1997 camry no dash lights a/c fan no windows
Hey I have just brought a 1997 camry well driving it home I noticed all the dash lights has turned off as well as the radiator fan the windows had also lost power any help regarding this would be greatly appreciated thankyou
Dash lights as in climate system, glove box, shift lever, etc to?
Do the tail lights and door locks work? Do the fans cycle on and off when the A/C is turned on? |
(Post 91861)
If front lights are blinking when AC or windows are working there may be a problem with the wiring, battery, connections at the battery, or alternator output.
The issue may be the power to the lights and other systems is weak. The extra load of the AC or windows now causes a further drop in voltage. Check the battery for full charge, alt is charging OR, battery cables and connections to battery are OK, battery ground cable connection. |
(Post 91876)
Check for power window operation at any window. If no power windows check Door, Gauge and Power fuses.
If taillight work the for dash light issue make sure the dimmer is turned up and check Panel fuse. |
