1999 Camry Alarm System Issues
Hello! I'm looking for a solution to my 1999 Camry's very annoying alarm system that I assume was factory installed (but not sure). Every single time I get out of the car, all the doors have to be locked and closed within 30 seconds or the alarm will go off. Also, when I get in the car, I have about 30 seconds to put the key in the ignition or the alarm will go off. The alarm has been this way as long as I've owned it. I purchased the car used from someone else. As you can imagine, the alarm makes the simplest tasks (pumping gas, taking groceries out of the car, etc) into a race against the clock.
Is there a way to disable the alarm system, or at least disable the "feature" of the system that requires me to put a key in the ignition within 30 seconds? Any other ideas on how to work around this issue? Thanks! |
Guessing the system is armed and has an entry time delay before alarm goes off.
See Private Message. |
