2001 AC Problem
I have a 2001 Camry LE 6 cylinder. My AC/Heat fan does not work on the 2 slowest of the four speeds. Any suggestions.
RE: 2001 AC Problem
Yeah, I had the same problem! The "Blowe motor resistor" goes bad and it will only work on the higher settings . . . Here it is . .
http://catalog.eautopartscatalog.com...Motor+Resistor I'm not saying that you should buy it from this site but that is the part you need. |
RE: 2001 AC Problem
I want to replace my blower motor resistor but don't know where it is located. Can you help me? My brother told me that it's almost certainly inside the blower plenum under the dash. Was he right?
__________________________________________________ Powered by Autopartswarehouse.com |
RE: 2001 AC Problem
I can only tell you where it is on for sure on92-96 models Ibecause replaced mine before. It is on the drivers side to the right of the gas pedal on the vertical surfaceof the center console. Maybe later models it is in the same place.
