2001 AC Problem
Old Sep 1, 2008 | 03:24 PM
aiello1218's Avatar
Default 2001 AC Problem
I have a 2001 Camry LE 6 cylinder. My AC/Heat fan does not work on the 2 slowest of the four speeds. Any suggestions.
Old Sep 1, 2008 | 04:17 PM
93camryxle's Avatar
Default RE: 2001 AC Problem
Yeah, I had the same problem! The "Blowe motor resistor" goes bad and it will only work on the higher settings . . . Here it is . .
http://catalog.eautopartscatalog.com...Motor+Resistor
I'm not saying that you should buy it from this site but that is the part you need.
Old Sep 2, 2008 | 06:48 PM
drewtiss's Avatar
I want to replace my blower motor resistor but don't know where it is located. Can you help me? My brother told me that it's almost certainly inside the blower plenum under the dash. Was he right?
__________________________________________________
Powered by Autopartswarehouse.com
Old Sep 2, 2008 | 08:00 PM
93camryxle's Avatar
I can only tell you where it is on for sure on92-96 models Ibecause replaced mine before. It is on the drivers side to the right of the gas pedal on the vertical surfaceof the center console. Maybe later models it is in the same place.
TMAC30
Mar 11, 2012 06:45 PM
chuckg
Sep 3, 2011 09:09 PM
frank2001
Oct 6, 2010 02:55 PM
jayexel
Nov 5, 2009 01:04 AM
red73mustang
Jul 12, 2009 09:21 PM
