2002 won't start, half the electrical doesn't work
2002 XLE V6
Wife reported something funny happening with the electrical on the way home. Now, when trying to start the car, the check engine light comes on and engine doesn't turn over, starter doesn't even click. -headlights, interior lights, door locks work -the following do not work with key in forward position: radio, AC, wipers, power seats, power windows Battery should be good, it's less than a year old, but I haven't pulled it out to have it tested. Fuses are good. Any ideas? |
So I went to Autozone and bought an Actron OBD II scanner. Whatever is wrong with the car is causing it to not supply power to the OBD port in the car. The scanner will not power up or display anything. I tested the scanner on my other vehicle and it works perfectly.
i suggest you get a auto diagnostic tool to check your car,mvci toyota tis is a great diagnostic tool for toyota,
have a try. |
Originally Posted by MrKeith
(Post 71008)
2002 XLE V6
unfortunately not many members come back and say they fixed the car and how
Joshua Lawson .. are they your exact symptoms... is it the same model camry is yours no crank no start and check engine light on ? do you have an anti theft or immobiliser system fitted..... is this an automatic |
Half of electrical wiring not working is massive. Fuses and ground wiring at first to check.
Originally Posted by dirty hands
(Post 92157)
If the electrical system was OK prior to parking the car.
Check for dead battery and corroded battery terminal connections (clean them). If the factory alarm was engaged, all electrical items would work including starter motor, but the engine would not start. The alarm prevents the engine from starting. |
(Post 92237)
