2002 won't start, half the electrical doesn't work
Old Apr 7, 2012 | 10:59 PM
MrKeith's Avatar
Default 2002 won't start, half the electrical doesn't work
2002 XLE V6
Wife reported something funny happening with the electrical on the way home. Now, when trying to start the car, the check engine light comes on and engine doesn't turn over, starter doesn't even click.
-headlights, interior lights, door locks work
-the following do not work with key in forward position: radio, AC, wipers, power seats, power windows
Battery should be good, it's less than a year old, but I haven't pulled it out to have it tested. Fuses are good.
Any ideas?
Old Apr 9, 2012 | 02:43 PM
MrKeith's Avatar
So I went to Autozone and bought an Actron OBD II scanner. Whatever is wrong with the car is causing it to not supply power to the OBD port in the car. The scanner will not power up or display anything. I tested the scanner on my other vehicle and it works perfectly.
Old Apr 16, 2012 | 10:50 PM
crazylove's Avatar
i suggest you get a auto diagnostic tool to check your car,mvci toyota tis is a great diagnostic tool for toyota,
have a try.
Old Jan 25, 2016 | 03:15 AM
Joshua Lawson's Avatar
Originally Posted by MrKeith
2002 XLE V6
Any ideas?
Did you ever find out what this was mine is doing the same thing
Old Jan 25, 2016 | 04:43 AM
dirty hands's Avatar
unfortunately not many members come back and say they fixed the car and how
Joshua Lawson .. are they your exact symptoms... is it the same model camry
is yours no crank no start and check engine light on ?
do you have an anti theft or immobiliser system fitted..... is this an automatic
Old Jan 28, 2016 | 03:09 AM
coldburn92's Avatar
Half of electrical wiring not working is massive. Fuses and ground wiring at first to check.
Old Feb 1, 2016 | 03:04 PM
Mine is a 2002 camry 4 cylinder my elec. Seats don't work windows don't work washer blade's don't work lights dont work radio don't work heater/AC don't work ... I do have dash light door looks dome lights .... it an automatic got stuck on ice and went from drive to reverse several times was my first automatic found out they don't like that tranny went out got the car home still started sat for a year with me going out ever other month or so letting it run bought new transmission went to start the car up and it don't click or crank the lights just go off don't want to do all the work putting new transmission in if it's not going to run the it just has the factory alarm system from Toyota
Old Feb 2, 2016 | 11:05 AM
If the electrical system was OK prior to parking the car.
Check for dead battery and corroded battery terminal connections (clean them).
If the factory alarm was engaged, all electrical items would work including starter motor, but the engine would not start. The alarm prevents the engine from starting.
Old Feb 2, 2016 | 03:14 PM
New battery and cables are good the transmission went out then it sat could the neutral safty switch mess with the electrical
Jlfrias
Dec 31, 2014 12:53 PM
Santanica
Feb 13, 2012 10:25 AM
bkpez
Apr 17, 2011 09:34 AM
drjeep1959
Nov 22, 2010 11:12 AM
beunos24
Jul 8, 2008 04:01 PM
