2004 Camry Wont Rev When Hot
Hello,
I have a 2004 Toyota Camry with 400000 Km (248548 mils), when the car is cold it runs starts and shifts perfect. The problem happens when the car warms up and drives for 45min, at first it won’t rev up past 4k rpm. When it gets hotter it gets worse wont rev past 3.5k then 3k. It just stutters and sits there no matter how much I press the gas pedal, does it in neutral as well. What I checked Air filter · Cleaned mass air flow sensor · Replace both cats on the car · Changed all plugs · Checked trans fluid · Checked fuel pump filter I did some looking online and found people having a similar problem and fixed it by replacing the crank position sensor. Any ideas or help would be great Thanks in advance |
UPDATE
I replaced the crank position sensor with a Toyota one, and problem solved. Drives smoother and does not stutters, drove it for 2 hrs and its fine. |
Good to hear you figured it out, nice! And welcome to the forums.
