2004 Camry Wont Rev When Hot
Hello,
I have a 2004 Toyota Camry with 400000 Km (248548 mils), when the car is cold it runs starts and shifts perfect. The problem happens when the car warms up and drives for 45min, at first it won’t rev up past 4k rpm. When it gets hotter it gets worse wont rev past 3.5k then 3k. It just stutters and sits there no matter how much I press the gas pedal, does it in neutral as well.
What I checked
Air filter
· Cleaned mass air flow sensor
· Replace both cats on the car
· Changed all plugs
· Checked trans fluid
· Checked fuel pump filter
I did some looking online and found people having a similar problem and fixed it by replacing the crank position sensor.
Any ideas or help would be great
Thanks in advance
What I checked
Air filter
· Changed all plugs
Thanks in advance
Luke LaVanda
Sep 29, 2013 01:06 AM
ivaylonikolov
Mar 24, 2011 03:46 PM
