2005 Camry Sunroof problem
My 2005 Camry XLE sunroof does not shut completely level with the roof lately. I have read about some procedures to reset the sunroof "home" position. Does anyone know about this?
Thanks! |
This is for an 02 model which is the same generation.
Toyota may have used two different sunroof manufacturers, there could be two different reset procedures. Procedure 1 -Push and hold switch on the "Tilt Up/Close" side until roof stops moving. -Continue to hold same switch for 10 seconds until roof is fully closed. -Continue to hold same switch until roof tilts all the way up and down slightly automatically. -Confirm one-touch slide open and close and "one-touch tilt up and down" by pushing the switch briefly to the "slide open" and "tilt up" sides. Procedure 2. -Press and hold "tilt up" switch until roof tilts all the way up then down slightly. -Release button and within 5 seconds push and hold "tilt up/close" button. The roof should move to full open then full closed by itself. -Release button. -Confirm normal operation by doing the last step listed for procedure 1. |
