2005 Camry Sunroof problem
Old Oct 10, 2012 | 04:20 PM
bae77345's Avatar
Default 2005 Camry Sunroof problem
My 2005 Camry XLE sunroof does not shut completely level with the roof lately. I have read about some procedures to reset the sunroof "home" position. Does anyone know about this?
Thanks!
Old Oct 11, 2012 | 11:05 AM
This is for an 02 model which is the same generation.
Toyota may have used two different sunroof manufacturers, there could be two different reset procedures.
Procedure 1
-Push and hold switch on the "Tilt Up/Close" side until roof stops moving.
-Continue to hold same switch for 10 seconds until roof is fully closed.
-Continue to hold same switch until roof tilts all the way up and down slightly automatically.
-Confirm one-touch slide open and close and "one-touch tilt up and down" by pushing the switch briefly to the "slide open" and "tilt up" sides.
Procedure 2.
-Press and hold "tilt up" switch until roof tilts all the way up then down slightly.
-Release button and within 5 seconds push and hold "tilt up/close" button. The roof should move to full open then full closed by itself.
-Release button.
-Confirm normal operation by doing the last step listed for procedure 1.
souftx
Oct 20, 2012 08:59 AM
brianjrealtor
Jun 27, 2011 01:42 AM
no1hardhat
Feb 14, 2010 09:48 PM
rpb008
Nov 15, 2009 08:42 PM
E_S
Aug 16, 2009 11:21 PM
