93 Camry No Speedometer and gas gauge reading full
Hello to all.
I have a 93 Camry with a Speedometer and Gas Gauge that has stopped working. Fuse is good. Is there a common spot or situation that causes this to happen that is known of? Any all info is Appreciated! Blessings Charles |
check the vehicle speed sensor. the wiring may be rusted or disconnected. as for the fuel gauge, it could be the same thing. rusted disconnected wiring. It could also be the fuel sending unit.
Thank you for your reply. Will check and re-post if problem is solved.
Blessings |
Does the trans shift OK?
Separate circuits. both receive power from the Gauge fuse. If the water temp, oil, charge, etc lights on the dash work, the fuse is OK. |
