93 Camry No Speedometer and gas gauge reading full
Old Dec 4, 2010 | 08:10 PM
ulremember's Avatar
Default 93 Camry No Speedometer and gas gauge reading full
Hello to all.
I have a 93 Camry with a Speedometer and Gas Gauge that has stopped working. Fuse is good. Is there a common spot or situation that causes this to happen that is known of?
Any all info is Appreciated!
Blessings
Charles
Old Dec 4, 2010 | 10:57 PM
mcglry's Avatar
check the vehicle speed sensor. the wiring may be rusted or disconnected. as for the fuel gauge, it could be the same thing. rusted disconnected wiring. It could also be the fuel sending unit.
Old Dec 5, 2010 | 11:35 AM
ulremember's Avatar
Thank you for your reply. Will check and re-post if problem is solved.
Blessings
Old Dec 5, 2010 | 01:09 PM
Does the trans shift OK?
Separate circuits. both receive power from the Gauge fuse. If the water temp, oil, charge, etc lights on the dash work, the fuse is OK.
krivraq
Mar 5, 2014 08:30 PM
marklee57
Feb 11, 2014 10:00 AM
jmkejbm
Jul 12, 2013 12:47 PM
vstadegt
Jan 20, 2011 12:54 AM
highalti2d
Mar 9, 2009 07:27 PM
