93 Toyota Camry Looses Anti-Freeze
Hello guys. I own a 93 Toyota Camry LE V6. I started to realize that air and anti-freeze always leak out of the overflow resevoir tube. How can this problem be fix?
I also had a incident were I was at Wendy's drive-thru and the overflow resevoir cap blew off. Is this because my radiator cap not keeping the pressure? If not, what can this be? |
RE: 93 Toyota Camry Looses Anti-Freeze
If air in the cooling system is blowing the top off the overflow bottle, you may have a blown head gasket.
The top blowing off the overflow bottle only happened once.
I don't think its the head gasket because there is no thick white smoke coming out my exhaust, my oil is not sluggish and my spark plugs is not white. I only think air and anti-freeze is coming out of the overflow tube because my radiator is losing pressure and I think my radiator cap need to be replaced. I just need some other opinions |
