96 camry front side marker lights
Hi,
I need to replace both front side marker lights. According to the owner's manual, after I remove the bolt near the side fender, I should be able to pull the assy straight out. When I tried to do this, I feel resistance like the light assy is connected to something that I can't see. Before I really yank hard on the assy, I want to know if it should be this difficult to remove and if there is any trick to removing the side light assy? Any tips would be appreciated. Thanks! -cj |
Your market lights
I am having the same problem. Did you ever receive a response...or figure out how to remove the marker lamp?
Thanks, Frank |
Seeing that I landed here from doing a search on google and no one answered this question here is a link to the answer, fir future possibilities
http://www.ehow.com/how_6663391_chan...996-camry.html |
I think there is a top screw that you need to loosen...to get to it, you have to remove the side "white" running lights that are next to the headlights to get to it...
