97 1mzfe
Hi all i stripped my 97 1mzfe for a rebuild and like a numpty didnt mark the inlet cams and was hoping someone has a way of telling the difference between the 2 or a picture of the cams when no.1 is at TDC
At TDC for No 1 compression stroke, the cam lobe orientation would be different for the front and back cams.
Install the cam pulleys and orient the pulley cam timing mark up. Then compare. See private message. |
