97 Camry CV joints - help!
Hi there,
Im trying to replace the outer drivers side CV joint on my dads 97 camry. Its the 3.0 V6 model (new zealand model). The trouble is I have the outer splined shaft out of the hub, no problems...but the outer CV joint wont come off the shaft...and the other side of the shaft wont come out of the transmission. What is the trick with the camry CV joints? Is there some sort of circlip on each end...does it just require brute force? I've read other posts saying 'just buy a rebuilt half shaft' but I havnt seen them for sale down here in New Zealand so I may have to replace just the outer joint. Any advice would be really appreciated, thanks so much!!! Mike :) |
RE: 97 Camry CV joints - help!
ORIGINAL: tiger_woods_fan ...but the outer CV joint wont come off the shaft... ...and the other side of the shaft wont come out of the transmission. |
Normally the outer CV joint is not removable from the shaft. As Pedro states the axle can be a pain to remove from the trans. The inner joint body may have a slot in it, if so place the end of the bar here. Then attempt to pop the axle out with a sharp, quick pry action.
Installing the new axle may also take a few attempts due to the clip. Make sure the axle is installed into the diff housing the ram it home quick and firm. If the axle does not lock in, repeat the process. Be careful not to damage the diff housing seal by accurately locating the axle before shoving it in. |
