Advice needed - Sealing a fixed panoramic sunroof
You folks have been very helpful in the past when working on my Camry, so I hope you don't mind me asking about my 2012 Toyota Venza.
I would appreciate any feedback or thoughts on the following... I found leaks on both rear sides of my fixed panoramic sunroof and circled them in blue in the photo below. When leaking, the water is always running along the inside frame; i.e., down the A-frame, over the rear tire wells, over the covered floor near the spare tire and into the dead space behind the tire well. Never touches the plastic trim or headliner. I visited three shops that repair leaking sunroofs and was told:
I am thinking about simply running a GE silicone sealant along the orange lines below. Thoughts, please. Thanks! JWKinRVA https://cimg4.ibsrv.net/gimg/www.cam...e5f2a27bdf.jpg |
The sunroof frame may have a drain hole at each corner leading to a drain hose going down each roof pillar (4 holes, 4 hoses). Make sure the hoses are not plugged.
(Post 109812)
No experience here in sealing car windows.
Sounds good on sealant though. Suspect no one wants to deal with it as they would be on the hook for leaks or its a big job. Use isopropyl alcohol to clean the joint and Q-tips or such to clean out the gap. Clean it well! Check into non-corrosive silicone that is not supposed to cause metal corrosion from acidic acid. Commonly available at hardware stores. This is used on home windows with metal frames. Might do a practice test for cure time as humidity and temp are factors. Home Depot had an off the shelf product years ago that was in a standard caulking gun tube, acid free and claimed it cured fast enough to not be concerned about rain coming in. Used it on a leaking sky light. Clean the joint well!!!!! Did a double bead to fill the window/frame gap. Tarped the window for a few days to keep out the water. Its been leak free since and no signs of joint degradation. Thought it was 3M product |
Thanks!
