Brake fitting leak?
I just replaced all four brake hoses on my 92' Camry (LF blew and just replaced the others for piece of mind). After tightening and loosening the steel line fitting/flare nut into the new brake hose several times to get a good tight seat and then spraying with "Brake Clean" to clean, I feel I am still getting a little seepage on all four fittings. In seepage I mean, the first exposed fitting/flare nut tread exposed above the brake hose end will have a slight fluid residue. After 24 hours it's still the same amount of slight residue. The steel brake tube going into the fitting/flare nut is always dry on all four.
Any ideas of what the slight fluid residue is from? I have loosened and retighten the fitting/flare nut several times and each time get a tweak more of nut rotation. I know this is the trick to get the seats to form tight, especially on stainless lines that I installed on another car. Thank you in advance! |
A flared fitting should not leak unless the flare portion of the tube is cracked.
A banjo fitting has two crush washers, you may need to replace these washers to get a good seal. Don't increase the torque beyond recommended, change the washers. |
