Brake fitting leak?
Old Aug 18, 2011 | 08:35 PM
camryss's Avatar
Default Brake fitting leak?
I just replaced all four brake hoses on my 92' Camry (LF blew and just replaced the others for piece of mind). After tightening and loosening the steel line fitting/flare nut into the new brake hose several times to get a good tight seat and then spraying with "Brake Clean" to clean, I feel I am still getting a little seepage on all four fittings. In seepage I mean, the first exposed fitting/flare nut tread exposed above the brake hose end will have a slight fluid residue. After 24 hours it's still the same amount of slight residue. The steel brake tube going into the fitting/flare nut is always dry on all four.
Any ideas of what the slight fluid residue is from?
I have loosened and retighten the fitting/flare nut several times and each time get a tweak more of nut rotation. I know this is the trick to get the seats to form tight, especially on stainless lines that I installed on another car.
Thank you in advance!
Old Aug 19, 2011 | 10:23 AM
A flared fitting should not leak unless the flare portion of the tube is cracked.
A banjo fitting has two crush washers, you may need to replace these washers to get a good seal. Don't increase the torque beyond recommended, change the washers.
spd0544
Jul 23, 2013 09:14 PM
Halen
Apr 19, 2013 09:35 AM
Sunside Jd
Oct 13, 2012 12:07 PM
sithunderbird
Mar 13, 2008 04:40 AM
camryn00b
Jan 18, 2007 11:39 AM
