Camry won't shift into 1st
My 2002 camry stopped allowing me to shift into 1st gear today. When I'm in neutral the shifter goes all the way to the left and I'm sure it would go further if it could. I just had the clutch replaced almost 5000 miles ago so I don't think that would be the issue. I have had a little issue getting into 2nd since I have been unable to shift into 1st also but I'm still able to. Any help or ideas would be truly appreciated!
check again the clutch master and slave for leaks
then the cable adjustment then bushes at the base of the shift stick then suspect syncros |
Originally Posted by dirty hands
(Post 93399)
then the cable adjustment then bushes at the base of the shift stick then suspect syncros I figured it out. Shifter cable broke :( |
now you know
a 2002 camry being an import .going to take some phoning around to source them today I cant find a parts listing for manual cables plenty of auto s cable expect these cables to be pricey you can try a bone yard or have them made up as new (needs the old cable as a sample ) take your time .. its a bit of a diy job to replace both cables |
