Camry won't shift into 1st
Old Jun 19, 2016 | 07:14 PM
Joellebelle's Avatar
Default Camry won't shift into 1st
My 2002 camry stopped allowing me to shift into 1st gear today. When I'm in neutral the shifter goes all the way to the left and I'm sure it would go further if it could. I just had the clutch replaced almost 5000 miles ago so I don't think that would be the issue. I have had a little issue getting into 2nd since I have been unable to shift into 1st also but I'm still able to. Any help or ideas would be truly appreciated!
Old Jun 20, 2016 | 04:24 PM
dirty hands's Avatar
check again the clutch master and slave for leaks
then the cable adjustment
then bushes at the base of the shift stick
then suspect syncros
Old Jun 20, 2016 | 04:52 PM
I figured it out. Shifter cable broke
Old Jun 20, 2016 | 06:18 PM
now you know
a 2002 camry being an import .going to take some phoning around to source them
today I cant find a parts listing for manual cables plenty of auto s cable
expect these cables to be pricey
you can try a bone yard or have them made up as new (needs the old cable as a sample )
take your time .. its a bit of a diy job to replace both cables
jakeymagoo
Jul 20, 2011 07:16 PM
ziddey
Apr 27, 2010 10:12 PM
vzehler
Oct 28, 2008 09:09 PM
azazel_18_2
Apr 22, 2007 05:42 AM
