Distributor cap seal
Hi - I pulled my distributor to replace the ignition coil on my 95 4cyl camry. I replaced the distributor O-ring. I am confused as to what is applied to the new ignition coil. It says seal packing - is that just FIPG (formed-in-place gasket) ? Or is it an actual seal. Also I
cant find a new distributor cap seal anywhere. I tried Toyota, NAPA, Autozone, and Pep Boys. It tore when I removed the ignition coil. Does anyone know where to get this or should I just use FIPG for that as well? Thanks |
distributor cap seal come whit every new toyota cap , ing. coil doesn't need anything applied to it
out of the 5 times I have changed the cap, rotor and wires I never bought parts from the dealer and none of the aftermarket caps ever came with a seal
at my job (toyota dealer ) every time i ask parts for the cap it comes whit the seal , unless they order separate and add it to the box later ... ill ask parts dpt. tomorrow
that would be great - I looked online and think the toyota part # is 19127-74050
seal it's a add on from parts dpt
