Engine misfire after replacing radiator
I replaced radiator last month now my car has developed a rough idle when stopped and when accelerating. When I got the CEL, I had the codes read at Advance Auto.
The codes are water temp sensor, P0301, P0302, P0303, P1349. I finally have time to work on it and any advice will be greatly appreciated. Could a bad water temp sensor cause the VVTi to misfire the cylinders? 02 Camry 2.4 I4 |
Possible causes:
Coolant sensor computer. At 68F ohm reading should be 2.29-2.6 Kohm. At 176F 0.300-0.327 Kohm. Oil control valve for VVTi. Check ohm resistance at two wires when unplugged - Should be 6.9-7.9 ohm at 68F Remove valve and apply 12v DC power to 2 wires- Valve action should be smooth in both directions with no sticking. Valve should fully return to home position. |
