Old Aug 27, 2015, 11:58 AM
How-Tos on this Topic
Browse all: Cooling System
Print Wikipost
Engine misfire after replacing radiator
Old Aug 17, 2012 | 03:20 PM
Texavant's Avatar
Default Engine misfire after replacing radiator
I replaced radiator last month now my car has developed a rough idle when stopped and when accelerating. When I got the CEL, I had the codes read at Advance Auto.
The codes are water temp sensor, P0301, P0302, P0303, P1349.
I finally have time to work on it and any advice will be greatly appreciated.
Could a bad water temp sensor cause the VVTi to misfire the cylinders?
02 Camry 2.4 I4
Old Aug 18, 2012 | 11:39 AM
Possible causes:
Coolant sensor computer.
At 68F ohm reading should be 2.29-2.6 Kohm.
At 176F 0.300-0.327 Kohm.
Oil control valve for VVTi.
Check ohm resistance at two wires when unplugged - Should be 6.9-7.9 ohm at 68F
Remove valve and apply 12v DC power to 2 wires- Valve action should be smooth in both directions with no sticking. Valve should fully return to home position.
breber8
Jul 12, 2021 12:28 AM
Boostedmuscle22
Jul 10, 2015 01:18 PM
dhabu02
Jun 14, 2013 05:30 PM
baz
Jun 2, 2011 01:46 AM
yngdvr1978
Sep 15, 2008 10:13 AM
