Ethanol fuels
For a 2000 stock-standard auto Camry Conquest, would 10% ethanol Unleaded petrol (ULP) be damaging?
I've been told of possible issues using this: # If you don't go through tanks in under a month the fuel will become "wet" (not good); # If there's sludge in the bottom of the tank the Ethanol will dislodge it which can clog fuel pump/fuel filter/injectors... # On older cars (pre-1997 or thereabouts) anything more than E5 will start to 'eat' fuel lines and rubber fittings. # It may produce worse distance per tank than standard ULP. So if anyone else has used this fuel or knows what would happen if I put it in mine, please share! Thanks in advance. |
You should be fine. The owners manual will explain fuel requirements. You will notice a drop in mileage of about 10% though as ethanol contains less energy. I avoid ethanol if I get a choice; one for the mileage loss and the other because it's stupid to waste valuable food production on fuel production.
Cheers Pedro, I agree with the waste of food production, too!
I'll probably leave it since, from what I know and you confirm, there's poorer performance. I'd rather pay more for better performance and distance! |
